Unterschied Donic Defplay Senso / Butterfly Defence Pro
Verein: SV Mindelzell
Spielklasse: Bezirksklasse A
TTR: 1322
Beitrag von arrigo »
Da es das Defence Pro bei Butterfly gerade im Angebot gibt und mich das Holz schon lange reizt, würde mich mal der Unterschied zum von mir gerade gespielten Donic Defplay Senso interessieren, damit ich das Holz für mich einordnen kann (evtl auch in Verbindung mit dem Curl P1r 1.1mm bzw. Feint Long II 1.1mm).
Danke schon mal, Gruß Harald
Dancer in the dark
Verein: Belgien
TTR: 1700
Re: Unterschied Donic Defplay Senso / Butterfly Defence Pro
Beitrag von Dancer in the dark »
Defence pro is stiffer, faster, heavier, shorter but thicker handle, head shape like JSH. I like it better than Defplay...
Holz: Joo
FH: Bluefire JP03 1.8
BH: Curl P1r 1.1
TTR: 1322
Thank You "Dancer", so when the defplay is closer to the joo blade is it as fast as the joo?
Dancer in the dark
Verein: Belgien
TTR: 1700
You can reply in German if you want, I can understand it well but writing it is more difficult...
It is not the Defplay but the Defence Pro that is closer to the Joo-blade. Although there some simularities between Defence Pro and Joo, Defence Pro is still slower and feels softer than Joo. Joo has absolutely the best feeling for powerlooping and also has the ability to keep chops low (flat curve). Compared to Defplay, chops return faster to opponent with Joo (and also with Defence Pro), so the price you have to pay is a less control...
So IMO:
Speed: Joo > Defence Pro > Defplay
Stiffness: Joo = Defence Pro > Defplay
Hardness: Joo > Defence Pro > Defplay
I will probably try the FLII 1.1 on the Defence Pro later this year...
Holz: Joo
BH: Curl P1r 1.1
